12" TC Sounds LMS-R d2
  • 6
k3n12ock
MD/CNY
TC Sounds LMS-R 12" DVC Subwoofer 293-658
Specifications: • Power handling: 1,000 watts RMS/4,000 watts peak • VCdia: 3" • Le: 4.7 mH • Impedance: 2 ohms per coil x 2 • RE: 3.96 ohms • Frequency range: 15 - 150 Hz • Fs: 28.0 Hz • SPL: 84.5 dB • Vas: 1.38 cu. ft. • Qms: 6.70 • Qes: 0.46 • Qts: 0.43 • Xmax: 29.4 • Dimensions: Overall diameter: 12.60", Cutout diameter: 11.16", Depth: 7.15" • Weight: 38.2 lbs.
Dual 2 ohm. In good condition. New in January from Thilo. Only saw about 500rms for about a month or so. No dents on cone. Some scratches on basket. I have the shipping box but not both. Box is big enough to fit both in with a foam on top. I can remove them and ship separately but shipping would go up a bit. I am the 2nd owner.
$300 shipped to your door, or your mama's house.
Trades for an 18" or 2k - 2.5k amp (aq2200 or similar)
USPS
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
680
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
k3n12ock
k3n12ock
MD/CNY
k3n12ock
    Jun 15, 2024
    Jun 15, 2024
