12" Sub For 6.5" Components or Coaxials
  • 4
dross93ranger
I need some good 6.5" or oversized 6.5's for my van. The sub i am wanting to trade is a 12" Polk Audio DXI
Size 12 -inch
Impedance 4 ohms
Cone Material Polymer Composite
Surround Material Butyl Rubber
Ideal Sealed Box Volume (cubic feet) 0.88
Ideal Ported Box Volume (cubic feet) 1.5
Port diameter (inches) 4
Port length (inches) 10
Free-Air No
Dual Voice Coil Yes
Sensitivity 88 dB at 1 watt
Frequency Response 27 - 200 Hz
RMS Power Range (Watts) 50-360
Peak Power Handling (Watts) 720
Top Mount Depth (inches) 6 1/16
Bottom Mount Depth (inches) 6 5/8
Cutout Diameter or Length (inches) 11
Vas (liters) 87.8
Fs (Hz) 30
Qts 0.5
Xmax (millimeters) 18.5
Parts Warranty 1 Year
Labor Warranty 1 Year
Sorry bout that!
Also I did not mention the condition of the sub. The sub was installed for 2-3 months and works perfectly and sounds great. I can hook a multimeter to the voice coils and take a picture if anyone needs the assurance. I took it out only to upgrade to 2 Type R 12's.
Anybody? I could also accept some 6", 4", or 4x6" speakers! I need to get rid of my crappy stock ones and I have an amp on the way!
Two subs, same issue, two LOC's same issue, seems to me that there is an issue pstream. Have you tested the amp disconnected from the signal...
494
526
627
dross93ranger
dross93ranger
Maysville, KY
mylows10
    Jun 3, 2024
