12" Replacement suggestions
adixon816
Friend dropped a tire iron on my tidal audio sub and split it well. Going to replace it and not sure if I want to get the same one or try something else. Box is ported 2 cubic feet tuned to 30hz with an aero port. Powered by a kicker dx250.1. Looking for viable suggestions to just drop right in, has to run at 2ohms. I listen to a lot of rap and hip hop and some rock to.
How much are you looking to spend. Also 250 watts isn't a lot to play with most subs people will suggest will be at least double that. (From what I've seen)
This is what I'd suggest though.
Incriminator Audio 12 I Series 300RMS 12" Subwoofer dual 4 and wire it to 2 ohms.
store.soundsolutionsaudio.com/products/incriminator-audio-12-i-series-300rms-12-subwoofer.html
How much are you looking to spend. Also 250 watts isn't a lot to play with most subs people will suggest will be at least double that. (From what I've seen)This is what I'd suggest though.
^^^This^^^
Sundown E Series
SSA Dcon
Decided to upgrade my amp to an alpine mrp-650. Alpine says 8 gauge for the amp with a 60 amp fuse. Should that be ok I already have that and would prefer not to upgrade my wiring.
Bigger is always better, but if they say its fine than its fine. You also have more options in subs with that power.
Sundown SA
Incriminator Flatlyne
Soundqubed HDS200
SSA Gcon
Check out this store >>> SoundSolutionsAudio's Online car audio store! Best prices, products and customer service. Fast shipping to US, Canada and More!!
They have all those.
adixon816
adixon816
South Bound Brook, NJ
adixon816
