12" MA Audio HardKore Series
so you need like 3krms to get these things going. Look in to a sundown 3000D or a crunch 3000D even a kicker 2500.1 would get hese things moving, you say you have a dielsel audio amp, never heard of it. However those dual KX1200.1 strapped will make enough power if you have the electrical system to back it up.
Hopefully they get a loud as you want. though I would not pu two in boxes that are too small, you will be sounding a lot better if you just do one with propper airspace and power.
Though if you can build your own box this should not be a problem, what would be a probelm is putting MA audio subs in prefab enclosures,
pound those woofers for while and then get some real subs. Like I said, hopefully it will get as loud as you want.
hey skateboardkid wtf are you talking about those MA Audio subs are some BANGERS the only thing that can match up to those in my opinion are the orion hcca a fi btl or a re audio MA Audio doesnt make garbage subs the make competition subs i talked to a guy down here at the local audio shop and 2 of those 12" under powered hit a 146.8 the only thing wrong is the box specs are wrong that the factory gives they say 3cuf but they have um in like a 2.3 cuf box and there beating his car apart and there really under powered there pushing each with 4000 watts a peice no cliping or bottoming out nothin running perfect
4000 a piece is under powering? The factory specs of 3ft^3 is wrong because the dealer has them working in 2.3ft^3, wtf? No clipping, do they have an oscilloscope? What? I'm sure they wang but that dealer is full of retards.
NissanKicker
Honda-on-22-Nissan-on-20
NissanKicker
Ruston/Grambling, LA
BloWNMind
