OP
yea i do listen to mostly rap and r&b. what would you recommend on tunin?12 in the proper size box should be louder. 3cubes really isn't enough for a 15. 35hz tune is fine for them, but if you listen mostly to rap I'd tune a little higher...
Wtf? lol
x2....exactly what I was trying to say12 in the proper size box should be louder. 3cubes really isn't enough for a 15. 35hz tune is fine for them, but if you listen mostly to rap I'd tune a little higher...
yea i asked that? a 12 in the right size box then a 15 in a kind of small box.If you have the room why opt for the smaller 12? With the power you have your going to want the most efficient set up, as I assume your going to want SPL, b/c your are buying an SPL sub.
Wait, did you really just ask what will get louder and lower, a 12 or 15?
Why must the 15 box be 3cubes though.
yea my trunk is huge, but i have other things that i also need the trunk forDoes the impala trunk not have enough room to fit the proper box size for a 15? I think they do?
Just get the sub you can put in the optimum enclosure. With that low of power the 15 in a small box is not going to be the ticket.
Put the 12" in 2.25 cubes net for best results. The 15" works best in 3.5-4 cubes net. For a daily driver tune 36-38, for spl tune 38-40. Allow 14-16 sq" of port opening per net cubic foot of internal volume.yea i asked that? a 12 in the right size box then a 15 in a kind of small box.
Cause i will still b usin the trunk. & 3 cubic is the biggest im tryin to go
you can take that answer to the bank..... thanks for chiming in DJPut the 12" in 2.25 cubes net for best results. The 15" works best in 3.5-4 cubes net. For a daily driver tune 36-38, for spl tune 38-40. Allow 14-16 sq" of port opening per net cubic foot of internal volume.
