12" Eclipse SW8200
bumpin buick
Science is everything
1. Product:
12" Eclipse SW8200 (TC based)
Been sitting at an eclipse dealer shop for 5-6 years in the back with a bunch of other old gear, the guy called me and said it may be something id be interested in. LMS coil, copper shorting ring on ID of slugs, removable baskets, 9.75" spider.
38mm xmax
$200+ shipping
--- mechanical ---
Fs 22.792E+00 Hz Free air resonance
Qms 4.262E+00 Q mechanical
Vas 81.385E-03 m^3 Suspension compliance
Cms 223.135E-06 m/N 1/(suspension stiffness)
Mms 218.523E-03 kg Moving mass
Rms 7.343E+00 kg/s Mechanical resistance
Xmax ** 0.000E+00 m Maximum acoustic linear motion
Xmech** 0.000E+00 m Mechanical displacement
Dia 254.000E-03 m Piston diameter
Sd 50.671E-03 m^2 Piston area
Vd ** 0.000E+00 m^3 Displacement volume
--- electrical ---
Qes 770.670E-03 Q electrical
Re 2.855E+00 ohms Voice coil DC resistance
Le 1.062E-03 Henries Inductance @1 kHz
Z 8.971E+00 ohms Impedance @1 kHz
BL 10.766E+00 Tm Motor force - Newtons/Amp
Pe ** 0.000E+00 W Max Electrical Power
--- electro-mechanical ---
Qts 652.644E-03 Q total
no 117.488E-03 % 1/2-space ref efficiency @ 1m/1W
1-W SPL 82.718E+00 dB sensitivity at 1m on-axis
2.83V SPL 87.193E+00 dB sensitivity at 1m on-axis
--- motor constants ---
Krm 13.063E-03 ohms constant resistive motor impedance
Erm 659.072E-03 exponent resistive motor impedance
Kxm 16.241E-03 Henries constant reactive motor impedance
Exm 707.456E-03 exponent reactive motor impedance
Phil... I wanted those motors.
used one to snag a sw8K, paid cash for this after selling a proto 12, I will have 5 now, i thought we were going straight cash for the lmt 12, ugh... misunderstood, I was planning on $330 plus shipping for it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Copied wrong specs wrong place lol, SW8200 TSP's from this driver
Re = 3.2856 ohms
Fs = 22.0150 Hz
Zmax = 23.5699 ohms
Qes = 0.9382
Qms = 5.7920
Qts = 0.8074
Le = 1.0685 mH (at 1 kHz)
Diam = 256.5400 mm ( 10.1000 in )
Sd =51689.2299 mm^2( 80.1185 in^2)
Vas = 87.1135 L ( 3.0764 ft^3)
BL = 10.5028 N/A
Mms = 227.7101 g
Cms = 229.5200 uM/N
Kms = 4356.9180 N/M
Rms = 5.4381 R mechanical
Efficiency = 0.0931 %
Sensitivity= 81.7071 dB @1W/1m
Nice lol.
Its cool. Im working on it now. Have some special cones on the way for you:)
And thanks for the tsp's!
bumpin buick
bumpin buick
Appleton, Wisconsin
smarkwilson
