100 Watts
Will I notice a difference?
  • Yes
    Votes: 4 44.4%
  • No
    Votes: 5 55.6%
  • Total voters
    9
thank for your reply
but wouldnt it be less than a 1db difference?
also...main reason I wanted to get a new amp was due to the fact that my gains are currently at 75% (I want to avoid possible clipping).
It doesn't matter what your gains are set to as long as it's set correctly. If your HU put out 6v and your amp accepted a max of 5v then the amp would be clipping at 0% gain when the volume is cranked up. If the max sensitivity of the amp was 1v and your HU only put out .5v then you could turn your gain to 100% and not clip and the amp would never reach it's full power. Basically don't worry bout what position the gain is turned to, just set the gain using a DMM using the stickies.
10*log(500/400) = .97db (theoretical maximum)
Figure by the time you account for power compression, etc, the difference in output will drop to around .5db or so.
The likelihood of the difference being audible is very low with less than a 1db theoretically maximum difference, and a realistic difference of around .5db-.75db at most.
Slammed
Striking Accord
Slammed
Gotham City, NY
David12460
