10 speakers... what amps???
DustinJ
ok everyone i'm doing my stereo on my boat and i need HELP!! i have 6 boston sl65 in 1 box on my tower i'm running 3 and 3 in parallel so i only have two sets of wires coming out wich is only coming out at 1.3ohms. then on the inside i'm running i pair of focal cv1's and i pair of eclipse sc8264 components. i want to run 2 and 2 in parallel with those also so i only have two sets of wires coming up front and that will give me 2 ohms per side on those. i'm trying to only use 2 amps at the most but my problem is finding a 1ohm stable amp for the 6 bostons. does anyone have and suggestions.... i like to only use really good name brands so please give me some choices or different ways to wire these. thanks, dustin
ps. watts....
BOSTONS 60w rms
200w peak
eclipse 100w rms
300w peak
focal 70w rms
140w peak
thats alot of mids and highs that shittt should scream man
what kind of boat is that going in
i have a action craft flats boat and plan on putting a 12 jl in the center console and mount two 6x8's in the console and then put two selenium horns under the polling platform and give the jl around 100rms its only rated for 125 so you know and give the seleniums around 100rms a piece and then give the 6x8's the hu power send each speaker two channels so around 35rms
what boat are you putting that into though
DustinJ
DustinJ
Stockton, Ca
kovemaster559
vegang
vegang
