10" TC9 Single 4 Ohm Sub (Incredible Condition)
The_Grimy_One
Phoenix, AZ
10" TC9 Single 4ohm
Courtesy of forum member @ciaonzo
"I mounted the top assembly to a motor from an Eclipse SW8200. Why? Because it has two 1" slugs and a huge copper ring down in the motor. Which means one very powerful, low distortion 10". Would work great in a very tiny sealed enclosure but I would throw this in a vented enclosure tuned to 25-28Hz and give it 800-1200w. Would be loud, low and clean. Driver looks phenomenal but I should note there is a bit of epoxy left on the motor from removing the heatsink. A bit of wire wheel would make quick work of it."
I have only used the sub for maybe 2 weeks. It sounds incredible.
I would give it a 9.9/10 all around
$200 Shipped OBO
UPS
How well would this work in a t-line or folded horn?
Sent from my SM-G925T using Tapatalk
Let me see if I can find out for you.
---------- Post added at 08:34 AM ---------- Previous post was at 08:33 AM ----------
$165 shipped, gifted...
I have a lethal injection im trying to offload (previous gen with the badge logo) **** near brand new (LITERALLY only ran for a week)
tis a 10 D2
tis a 10 D2
Let me think about that. I believe that generation was 600rms right?
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
654
978
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
The_Grimy_One
The_Grimy_One
Phoenix, AZ
The_Grimy_One
