10" TC9 Single 4 Ohm Sub (Incredible Condition)
The_Grimy_One
Phoenix, AZ
10" TC9 Single 4ohm
Courtesy of forum member @ciaonzo
"I mounted the top assembly to a motor from an Eclipse SW8200. Why? Because it has two 1" slugs and a huge copper ring down in the motor. Which means one very powerful, low distortion 10". Would work great in a very tiny sealed enclosure but I would throw this in a vented enclosure tuned to 25-28Hz and give it 800-1200w. Would be loud, low and clean. Driver looks phenomenal but I should note there is a bit of epoxy left on the motor from removing the heatsink. A bit of wire wheel would make quick work of it."
I have only used the sub for maybe 2 weeks. It sounds incredible.
I would give it a 9.9/10 all around
$200 Shipped OBO
UPS
[quote name='The_Grimy_One']Item(s) for Sale:
10" TC9 Single 4ohm
$200 Shipped OBO
UPS
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). [/QUOTE]
Trade for another 10? Hdc3 minty
How long did you run here and what kind of power?
---------- Post added at 10:28 PM ---------- Previous post was at 10:28 PM ----------
Her*** lol
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
522
810
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
981
The_Grimy_One
The_Grimy_One
Phoenix, AZ
The_Grimy_One
audiobaun
    May 19, 2024
    May 19, 2024
