I'm not arguing that you're moving air. Obviously a ported box will have airflow from the port.
However, you have no numbers to back up that you think you are moving MORE air in and out of the enclosure.
Have you ever seen a car doing high numbers with a big box and a gigantic port? Hell no, so think about stuff before you post.
More air does NOT mean a higher SPL reading. Take a look at assman's van. That thing moves an ASSTON of air, yet it won't meter as well as a pair of 10's in a crx. Explain that one to me mr. wizard.
Besides, port velocity is only one of MANY factors that determine whether a box will meter well. And actually, you want to maintain some pressure inside the enclosure. Having that large of a port (non-flared) will fail to do that.
Regardless, you are going completely beyond the realm of SPL physics with this test. Air movement out of the port is all fine and dandy, but scale that down into a vehicle and see if you get the same results. Getting high SPL is a combination of port velocity, sub movement, and the vehicle itself. You have one of the three. Better luck next time.
I got a pretty simple test to see what this box is actually doing. Put an SPL meter in front of the port. Find out what it reads. If you can do that, with a video, then I'll show you what my properly designed single 10" box does. That will end this train wreck of a thread.
