When have we ever debated on the topic of distance the air moves inside the port? We were discussing port air velocity.
I think its pretty clear you took offense to my 'make noise' comment. It was not a comment to suggest performance levels, merely that your video only shows it does in fact... make noise. Holding a bag over the port to see it move measures port air velocity? And what are we comparing the bag flapping to? What we think the bag would do with a 4" port?
Bag flapping does show air is moving. It even shows alot of air is moving (never debated), but it does not show velocity nor give any indications of what would happen to velocity were the port area to change.
You seem to be trying to suggest that greater port area does NOT equal lower port velocity. Are you then suggesting port air velocity is always constant, no matter the port area? Or, are you suggesting port air velocity INCREASES as port area goes up? The answer is... you are confusing the amount of air displaced, with how rapidly it moves within the port.
Besides the specific numbers, all of that was predicted for you by us before you ever built this box. You seem to be trying to wage a quantitative argument while using subjecting information (your video) as your proof. That never works out well. But I do applaud you trying this, and sharing it with us.
I would have guessed it would 'bottom out' with rated power going to it? Why would I do that? You seem to be forgetting that as you increase port area, you also increase port length. What does this mean to the subwoofer? The same over resistance seen to air movement/pressurization/cone movement. Also, seeing as cone motion in a vented situation is so drastically controlled by frequency, I dont see the point in making such an argument about bottoming out unless we are talking about deviating far from tuning (mostly down). And that is what I DID say in the previous thread. You've already admitted it unloads faster than normal below tuning, got you to admit half my argument.... now tell us, how's its upper frequency performance? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
