1. Product:
(1) Sundown Audio SAZ 2500D
(2) Alpine PDX 1.600
(1) Alpine MRD-M1005
2. Specs:
(SAZ 2500D) - 2500 watts rms @ 1 ohm
(PDX 1.600) - 600 watts rms @ 2-4 ohms
(MRD-M1005) - 1000 @ 2 ohms
3. Description/Condition:
SAZ 2500 - 9.5/10 Cosmetic - one minor scratch by top left saz 2500 print, only noticeable in certain light (pictured below) 10/10 Mechanical, works great never any problems, doesn't go into protect and has always been run on good electrical with kinetik battery bank of 2400s.
PDX 1.600 - 10/10 Cosmetic, 10/10 Mechanical - Perfect Condition, like new considering they are used. They are very closely matched because they were purchased new at the same time, wattage should match on each amp if you wanted to run two together. One minor chip on one of the 4 caps, if you link them together they will be removed.
MRD-M1005 - 8/10 Cosmetic, 10/10 Mechanical - a few minor scratches, the cover is a little scuffed up but doesn't look bad, I thought about wet sanding the cover and polishing it up since it is aluminum, can most likely get a mirror finish on it.
4. Price: :
SAZ 2500D - $575-----NOW $550
PDX 1.600 - $200 (each)------NOW $150 each
MRD-M1005- $300 -----NOW $250
5. Pictures:
Feel free to message me on here or email tprice07@gmail.com if my pm box gets full. All amps have been tested and verified to work prior to posting up on here. I can also order new Sundown Audio amps and subs so PM for quotes and I will do my best to forward you onto a rep/dealer if out of my area. Thanks!
2. Specs:
4. Price: :
5. Pictures:
