1" Dome Tweeter
ss3079
Eh Dere Hi Dere Ho-ser
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-527
Need a tweeter very similar to that one, however, cheaper.
6ohm.
~1500-25, 000hz
Fs ~ 750hz
91 db 1w/1m
Something to work well with two 7's and two 5 1/4's in a tower.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-524
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=297-416 - would work, but power handling = //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
Any suggestions?
Thanks for the link. I can spring for something a little more expensive if you were looking to suggest something more than five bucks a pop. I should have clarified that - I don't mind spending 15-20 bucks or so per tweet.
...what if u don't need anything more expensive //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
but in that case
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=275-100
i'm using ^^^ the next time i need tweeters, they are so crisp and smooth.
if its that much of an inconvience, i'd just go with jim and say horns. a 3-way design, imo, is inferior to a good 2-way. they have better imaging, easier to build, and sound just as good depending on the enclosure.
The towers are already pretty much built.
I'm playing with the CNC router tomorrow ... hopefully get a program set up to cut the holes.
Yes, I could use a jigsaw.
Yes, I could use a router.
But there's a CNC, so why the hell not ? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
ss3079
ss3079
Up North
ss3079
