1 ID12 or 2 RE10 ?
i wish i hadnt stopped going to spanish class... then again we never learned anything //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
lol Just give it a try...
I know my english is awful, but I lost my pain. Now is you will have to support me muajajajaja
Everithing is fine while you can understand my ideas
Chao
BTW...I do recommend a ported 12" IDv3 over 2-10" sealed REs
For the 12" IDv3: 1.75 cu ft tuned to 28-29 hz...about the same size box for 2-10s in a sealed enclosure
the single 12" will get louder //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have 3 questions for you...
First, What do you think about 2-RE10s in a vented enclosure using the optimal box?
2nd. How much power you recommend for 1 ID12? I ask because the ID site tells 50-400, but the Spec Sheet tells 250 RMS
3rd. I'm using HT BBP, In the box Tab... What is your opinion about the fidelity of the program calculating the port dimensions? Is that Fb frequency reliable?
Also in the Vents Tab in HT BBP, there is a button that says "Suggest Minimun Vent Area for Xmax", The database shows a power handling of 250RMS...
For a 2cu/ft it says Area 215cm (like 33") Lenght 55"
So, If I give it like 350RMS is better to reduce the area right ? or no
mledez
mledez
Venezuela
mledez
