1 DC Level 4 15" D2 vs 2 RD Audio 12" D4 v1s
Ninja Primate
Ok I currently have a DC Level 4 15" D2 wired at 1 ohm in a 4 cube box tuned at 33Hz. Im considering trading for 2 RD 12" D4 v1 subs rated at 600RMS, but under rated. Ill be running off of a Cadence Z1200 at 1-ohm for either setup.
Which one will be louder in terms of SPL?
Which set would be punchy in terms of SQ?
Original Sonance v1 motors. Dual stacked magnet, 6.75" round, cast basket, bolted down spider rings, and same cone as the Sonance v2.
Box specs:
sealed -
10" .9 cube
12" 1.25 cube
15" 2.25 cubes
ported
10" 1.33 -1.5 cubes
12" 1.75-2.25
15" 3.0-3.5
I have not had a personal experince with the V1 sonance but Ive been happy with the v2 also you are gaining cone area so in theory it should be louder plus the subs are more effeceint. As for SQ I couldnt compare the two i think that is install dependent though.
Really Im looking for an SPL setup. Ill be gaining a little trunk space and still be with a ported box and more cone area off of the same power. Ive read these are basically SPL subs, but I was really looking for personal experience.
Ninja Primate
Ninja Primate
Behind You?
Ninja Primate
