1 amp per sub set up???
I havent played with both but ive heard from other people that supposidly have that the new IDv.3 is a better sub with more output than the the idqv.2, just requires slightly larger encloser. Ive also heard theres a IDQ v.3 on the way but have now info on release or t/s peramiters or anything.
If it's anything like the IDOne, don't hold your breath //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif It'll be a while before it's released........
Okay..one of the Knuckleheads on here will blast me for this newbie question but here goes..
ARC say I must run a 4 ohm sub because these amps are 250X1 at 4ohms....
Does this mean I cannot run a DVC 2ohm sub at all???Or just that I cannot run anything above a 4ohm
I can get some IDQ DVC 2 ohms at a great price???But will this work?
Okay..I Kinda understand...?
So If I am running a 4ohm load from 1 amp into a 1 sub..that sub MUST be 4 ohms not 2ohms..Does it matter if they are DVC subs or no?
Basically to run 1 amp per sub at 250X1 @ 4ohms per amp..I must use a 4ohm sub
Sorry..for some reason the Image Dynamics Sub options for DVC and Ohms confuse the hell outta me!
Depression
ISSUES
Depression
Los Angeles?PEBBLE BEACH NOW
squeak9798
