1.82 cuft sealed enough...
I'm pretty sure the 2cubes that SI recommends is after all displacement. The polyfill tricks the driver into thinking it's a larger box. You'd need a little over a pound and a half for your box of 1.82 cubes. I believe the ratio is 1lb polyfill to 1cube of airspace. I'm making a sealed box for my mag15 @ 2.5cubes and most likely won't be adding any polyfill.
-Marcus
Actually, after a little reading I did, it doesn't make the sub think the box is bigger.. read what Donn had to say on this subject.
its not really that the sub thinks the box is bigger....it changes the acoustical properties of the enclosure.
when you stuff any box full of fiberous material it slows the backwave. in doing so, you create better low-end frequency response. the amount the backwave is slowed is directly proportional to the amount of stuffing used. If your box sounds like crap below 40hz, pack that sucker full. if it gets a little response but not quite enough, just use the suggested 1lb/cuft.
I have a 15D2 as well, why are you going with 2.5 cubes sealed?? I am probably going to build my box closer to the 2 cubes recomended. is there any advantage to going 2.5?
I'm going a bit larger than recommended to provide a little better low end response.
-Marcus
Advantages of large sealed box over small sealed ...
- Less cone distortion
- Better transient response
- More accurate
- Louder low-frequencies
- Smoother roll-off
Have you checked out these shallow drivers from DD? A friend had 4 of them and man, it took it to the house for what they are...
6
184
The 8" sealed will not sound anything like a ported box. Even a 6" in a ported will hit harder than an 8" in a sealed. However, the bass, from...
10
602
That's good. The thing is finding a like 4 way splitter. Giving the exact reading coming out of the speaker outputs. I'm think he wants a big...
42
3K
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
3K
cjj2d
cjj2d
Murfreesboro
djvi0lent
Bobbytwonames
    Jul 26, 2024
Bobbytwonames
    Jul 26, 2024
