1.5 ohm load on a 2 ohm amp?
running an amp below its stable rated ohm load is a very touchy thing. some amps can be ran at virtually any load with no problem. but if your amp is rated at 2 ohms i would run it at 2 ohms. IF you have good electrical, and IF you are lucky you might be able to run it at 1.5 ohms. but if it wont do it the amp will either blow fuses, go into protect, or blow completley(more likley is blowing completley)
Matt
You also have to remember you have box impedance rise, you could probably have a final 2.5 ohm load even if your subs are wired at 1.5. It just varies per enclosure. So you should be fine, if your amp goes into protect then its too much for your amp. Like stated above dont set your gains to clipping.
Thanks. They guy I got the subs from didn't know if they were dvc and I haven't had the time to take 1 out and see. I just checked it and it was 1.5 ohm just on the speaker. I didn't have the amp on. Does that make a difference?
They r powerbass. Think they r the s series but haven't been able 2 check yet. I knew they sounded good in the box they came in and it wasn't a bad deal. I figure they are dvc
ok, for starters box RISE is only important to SPL competitors because they are playing ONE tone. on music impedance rises AND FALLS... if it only rose then you could essentially run a 4 ohm stable amp at 1 ohm all day in the right box. PLEASE read up on box impedance graphs before you cause someone new to audio to blow their **** up.
to the OP: unless you can find a ton of proof that your amp can run at 1.5 ohms please stick to 2 ohms.
Matt
babsuhl81
babsuhl81
decatur, il
babsuhl81
