nyg052003
- Thread Starter
- #16
Oh no I have kenwood 6x8's in front now that since I have them I will use in rear as rear fill and go with 6 1/2s up front. I will have the rears just well proportioned but probably not on same level as the 6 1/2s. So the mach box is ideal for using the 6x8s. If I had to buy rear speakers I would probably just do away with the box and have a few more inches to put a taller box for a 12 without having to slant the face to make a 12 fit but that's if I went with one 12. I will call Cscstang later and we will ponder over what's best and if that's one 10 or 12 or 2 10s would be fine.CSCStang will be able to do you up just fine. He doesn't need to have your car, as long as you give him good measurements. Or he might even already know a general size that does/doesn't fit in your car. You are going to be limited on sub selection by your car. And wanting/needing to keep the MACH system. DON'T fall victim to mutiple subs in inferior/too small enclosures, it WILL sound WAY worse than a single sub in a correct enclosure .... No matter what your buddies try and tell you ....
the mach 460 system was only used in my car for about 6 months when I bought it late 95 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
