1 4" Aero Enough for 2 cu ft?
the problem I come to by using 2 with this size box is that each port calls for being 32" long....I may take the box size up to 3.2 cu ft tho
Probably a good idea to increase box size, allowing for shorter port. Or if you have to, get creative with the way you put the ports, from the side, or half inside the box half out, etc
already ordered the 2 4" aeros //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
2 3" aeros work out perfect
1 6" aero = 28 sq in
2 4" aero = 25 sq in
1 4" aero = 12.5 sq in
2 3" aero = 14 sq in
You should be using around 20-25 ish minimum unless very low power
2 3's is pretty much just as insufficient as a single 4, and 1 6 is even harder to fit than 2 4's (unless surface area on the box is in issue of course).
btdickey99
I Hate the Tarheels
btdickey99
Burlington, NC
Rashaddd
