1 15' in the trunk with 3k
IMOVeCHICKENS!
Firtyfwe here ngz
finally got everything done alts in both amps hooked up only thing left is one more run of 0/1 from the front to back battery negative
the dc power 270xp next to the stock one
the lonely battery in the back
the 8in aero
amps and the subs
blue lights and voltage sittin high with amps strapped @1
heres the sub minus the comp cone i fried it as soon as i got it and got a standard dual 2 recone from DD
vid with one amp at one ohm
Just an //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif, when you're trying to take videos of your tin can Corolla flexing, you want to use the LOW notes. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Have you metered this setup yet? What is your box tuned to?
I bet your neighbors love you.
it bothers them but i never do anything for an extended period of time and try to be polite i had 2 AA chaos 15s in a sealed box before and a got a 142 on music on the TL im waiting for a comp thats semi close to me to get it metered and im tuned to 40hz
i rip harder *** than your 141 at 28hz
so 4 12s equalling 141 is a good scrore oooooooo bass sensei show me the magical truth of db drag lol
seriously i didnt want to tune to 40 hz but obviously i trying to make a box i can remove from my trunk no this isnt a low end monster and i never said it was but 9515g doesnt sound bad at all @40hz i was never claiming magical SQ out of my trunk
if i had a larger trunk opening and some more room to work with i would ve tuned to 35ish hz but space limitations>me
Using four 175W subs, and the score at 28 Hz? lol, you tell me.
Tell me, when you play a 28 Hz wave do you hear anything, or do you just hear the sound of your sub bottoming out in your 40 Hz tuned box? laaawl.
and its my fualt your broke *** couldnt get better subs or amps lol
i never even once stated that this was a low end monsted
but your just a tool on the forum ive read bs from you the entire time ive been on CA.com and all you do is talk how much "DA BOMB" being tuned low is i dont care about your 4 weak *** 12s hitting a 141 @28hz
oh and you need to find something better to do with your time you joined the forum 2 months after me and have like 3k more posts go get a ****in job and buy some real subs with some real power.
IMOVeCHICKENS!
Firtyfwe here ngz
IMOVeCHICKENS!
727 FLA
IMOVeCHICKENS!
