09 CDTs question with amp
those are actual specs, alot more then 150 =/u sure it will still work and not blow my new speakers if i have gains all the way down =[
RMS Power at 4 Ohms 250 W x 4
RMS Power at 2 Ohms 360 W x 4
With that much power, you might want to run 2 channels on the fronts, and leave 2 channels for the rears. 250w per channel is plenty of power, don't even need to bridge the channels unless you have a set that can handle more power. Email Vertex and see if they can recommend you a CDT that can handle more.
already bought the cd 61i
Well just the 6.5 componenet set u mean run 2 channels to two tweeters and other two to the 6.5's?
and i can just screw them in my door and the 6.5 should sound good still right
No you don't seperate the tweeters from the woofers. Each set is 1 complete kit. 1 channel runs 1 set(tweeter+woofer).
So if you're using those comps, I'd either run 2 of the 4 channels on those comps or bridge the 4 channels into 2 and run them with a low gain set. Both ways will get you the same results, but the first option will leave you with 2 empty channels for more speakers.
Make sense?
ohhh ok i see, what if i ran the other two channels to my stock 6x9 in the back of my 98 chevy would they blow right away
That's an option for sure. I would choose that route, maybe even replace those 6x9's with something that can take more power? You can run the stocks, just make sure to turn the gain way down.
well even with gain all the way down wont it still recieve the minium rms power?
No, the gain is the power control. You can set it between 0 and the (in your case) 250 watts per channel.
? or do they need a custom install to sound good
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif No gains are more like a sensitivity control that affects the power output in relation to the volume knob ie, a higher gain setting will use the amps maximum potential output sooner on the volume dial.
Your best weapon for not overpowering your speakers(/controlling your power) is common sense w/ the volume control
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif No gains are more like a sensitivity control, that affects the power output in relation to the volume knob ie, a higher gain setting will use the amps maximum potential output sooner on the volume dial.
Ok he has absolutely no clue what that means. In simple terms, yes a gain knob controls the power (output). Stop being so **** picky guys.
ok i understood that im not a idiot //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
just with car stereo stuff
but my question is if my friend just screws in the tweets and the 6.5's will they sound good or do they need a custom install?
416
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
764
That would be fantastic! Id love to see the skills involved here. It always intrigues me to see some customizing from small and detailed to large...
499
Magnatus
Banned
Magnatus
AZ
Magnatus
Brendon Jenness
    May 8, 2024
    May 8, 2024
