07 VW GTI sytem sql/ Quality?
mtnbikerva1
I just bought a 2007 2dr automatic GTI, Pkg 1 no leather, with sunroof.
With todays technology are all Amps the same other than power rating?
I listen to a lot of AM talk radio so I still need good AM reception.
When I listen to music I listen to all types except RAP, HOUSE, AND
INDUSTRIAL, I do listen to: Bluegrass, Jazz, rock, bagpipes,
pipe organ, motown, country, new age, punk, classical...
I am trying to decide what amps to go with. I think there are some
digital like Alpine. Also a/b, d
Should I go aftermarket head unit or stay stock and do I loose or
gain features on steering wheel or otherwise. I am not interested in
motorcycles flying across the display. I want to be able to read the
station time and important stuff in the daytime. I had a Pioneer
Premier from a few years ago and it was usless in the day.
I have Boston Accoustic Pro 60s I could use(1 set). I also have a
Precision Power Art series A404.2, Mb Quart 300watt sub amp, JL audio
300/2 slash 1.
Do I need some type of Processor like Clean sweep, 3sixty.2 .... If
so which one? One guy said the Rockford 3sixty.2 was a huge pain or
impossible to set up(TWEETER installer).
I do not want to spend more than my car cost on the stereo.
Where should I put the speakers in the doors? build some housing/
structure to put them/ mold them in door?
Should I do something about the back speakers or just unplug them and
use the fronts.
I will buy new equipment if it ends up sounding better and lasting
longer/ less problematic and ends up taking up less space.
MAIN THING IS I NEED BETTER SOUND QUALITY AND A LITTLE MORE VOLUME THAN STOCK.
ALL WISDOM APPRECIATED
THANK YOU!
ugh.
thats a lot of unorganized crap you posted.
firs let me start out with a few of my own questions.
why do you need more volume than stock if you listen to mostly AM talk radio? the stock system in my 03 Gti was loud enough for that. do you have the monsoon one?
i would always upgrade the headunit to something before i even attempt to install an aftermarket stereo because of complications (espically in VW's) that will arise.
as far as what to buy? go look. there are tons of headunits that will give you fine AM reception (that technology is what... 101 years old? they should do it well) and you may want to look into something like XM or Sirius satalite radio that is integrated into the headunit. you get better signal and lots more to choose from.
onto the system itself. ppi art amps are great quiality last a life time. and likewise with JL audio. if you wanted, you could install that and bridge it on your boston components (i think they are components?) and then get a sealed 10" subwoofer and hook that to your JL amp. with a headunit and those pieces of equipment installed, you would have a relativly cheap and effective stereo that looks like it can accomplish all the goals you have put forward to us.
mtnbikerva1
mtnbikerva1
reston
Eugenics
