06 randevue remote start
12volts orange (20A), orange (10A) + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition dk. green + ignition harness
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - ign harn or BCM, gry 16P plg, pin A5
Notes: The BCM is in the center console above the fuse block.
Power Lock red/black - dr kick or BCM, pink plug, pin B4
Notes: Lock is negative trigger thru a 470 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock same as power lock wire
Lock Motor gray 5wi DKP or fuse block, blk plug, pin B2
Unlock Motor tan 5wi DKP or fuse block, blk plug, pin A1
Parking Lights+ DO NOT USE
Parking Lights- lt. blue - sw or BCM, gray 16 pin plug, pin A6
Hazards tan - switch or fuse block, gry plg,pin E2
Turn Signal(L) lt. blue/white + switch or fuse block, gry plg,pin F2
Turn Signal® dk. blue/white + switch or fuse block, gry plg,pin F1
Reverse Light lt. green + fuse block, black plug, pin C10
Door Trigger dk. blue/white - BCM, pink plug, pin A3
Dome Supervision gray/black - fuse block, black plug, pin C9
Trunk/Hatch Pin pink/black - BCM, pink plug, pin A9
Hood Pin N/A
Trunk/Hatch Release white/black - BCM, gray 16 pin plug, pin B1
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm purple - dr kick or BCM, pink plug, pin A4
Disarm No Unlock see factory alarm disarm
Tachometer NOT pink or white ac any fuel injector
Notes: On the 3.5L models, can also use purple, red/white, or lt. blue at the ignition coil pack.
On the 3.6L models, can also use the wire that is NOT pink/black, black/white, or black at any ignition coil.
Wait to start N/A
Brake Wire white + brake pedal switch
Parking Brake orange/black - switch or BCM, pink plug, pin A1
Horn Trigger black - sw or BCM, gray 24 pin plug, pin A11
Memory Seat 1 white - mem mod under seat, gry plug, pin A3
Memory Seat 2 purple - mem mod under seat, gry plug, pin A2
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
PASS-Key III
Part #: 555GW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes: Can use the 457GW to bypass the PASS-Key III, but it will not control the door locks on this model year.
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Notes:
Smart Starter Kill Relays: Not Available
Stroker_Boy
Kendall
Stroker_Boy
Adrian, Mi
Shyne151
