J JOHNJOHN485 10+ year member CarAudio.com Elite 738 0 KENNER, LA Jan 19, 2007 #1 i need a box for 05 xxx 15 going in a 97 cutlass power by a hifonics bx1500d Click to read more...
Q quakerroatmeal 10+ year member CarAudio.com Elite 1,676 0 Dallas, TX Jan 19, 2007 #2 You probably need to give out max dimensions befor someone can help you. And what goal you are going for and tuning.
OP J JOHNJOHN485 10+ year member CarAudio.com Elite 738 0 KENNER, LA Jan 19, 2007 Thread Starter #3 anybody got the spec on this sub ?
OP J JOHNJOHN485 10+ year member CarAudio.com Elite 738 0 KENNER, LA Jan 19, 2007 Thread Starter #4 4.5cf tuned around 38 hz
OP J JOHNJOHN485 10+ year member CarAudio.com Elite 738 0 KENNER, LA Jan 19, 2007 Thread Starter #5 i can make my own box plan if i can get the qts , vas ,fs and the driver displacement
OP J JOHNJOHN485 10+ year member CarAudio.com Elite 738 0 KENNER, LA Jan 19, 2007 Thread Starter #6 the new re site only got the new xxx on there
OP J JOHNJOHN485 10+ year member CarAudio.com Elite 738 0 KENNER, LA Jan 19, 2007 Thread Starter #7 30x15x15
Q quakerroatmeal 10+ year member CarAudio.com Elite 1,676 0 Dallas, TX Jan 19, 2007 #8 FS 27.0HZ Re 1.9DVC Qms 4.52 Qes 0.44 Qts 0.4 SD cm2 480 Vas 56.5 l Xmax 1 way linear 32mm BL 17.1 SPL 1W/1M 85.9 RMS 1600w MAX 2500.w Cutout 11 1/8 Displacement 0.19cu ft Mounting Depth 8” Weight 56lb Sealed Enclosure .75-1.5 cu ft Ported 1.6-2.5@34hz Sub T/S Specs: XXX12 FS: 27.0Hz Re: 1.9DVC Qms: 4.52 Qes: 0.44 Qts: 0.4 Sd Cm2: 480 Vas: 56.5 Xmax 1way Linear: 32mm BL: 17.1 SPL 1W/1m: 85.9 RMS: 1600W Max: 2500W
G glowinramsport Junior Member 1 0 Saginaw, MI Jan 20, 2007 #9 are those specs for the 15? cause i was thinkin bout doin a 4+ cf ported box tuned to about 40 hz... as long as it fits in an extended cab fullsize dodge truck... but off topic were the top specs for a 15......?
