05 re xxx 15
FS 27.0HZ
Re 1.9DVC
Qms 4.52
Qes 0.44
Qts 0.4
SD cm2 480
Vas 56.5 l
Xmax 1 way linear 32mm
BL 17.1
SPL 1W/1M 85.9
RMS 1600w
MAX 2500.w
Cutout 11 1/8
Displacement 0.19cu ft
Mounting Depth 8”
Weight 56lb
Sealed Enclosure .75-1.5 cu ft
Ported 1.6-2.5@34hz
Sub T/S Specs:
XXX12
FS: 27.0Hz
Re: 1.9DVC
Qms: 4.52
Qes: 0.44
Qts: 0.4
Sd Cm2: 480
Vas: 56.5
Xmax 1way Linear: 32mm
BL: 17.1
SPL 1W/1m: 85.9
RMS: 1600W
Max: 2500W
are those specs for the 15? cause i was thinkin bout doin a 4+ cf ported box tuned to about 40 hz... as long as it fits in an extended cab fullsize dodge truck... but off topic were the top specs for a 15......?
JOHNJOHN485
JOHNJOHN485
KENNER, LA
glowinramsport
