02 Impala Wall
Looks good dude
Dont worry about what there saying about the shit not being strong enough, I had a few "glued gaps" in my wall, and as long as you throw 3-4 layers of mat around all the seams, and some good 2X2 (or in ur case 2x4s i guess ur using) bracing, shit will be solid.
Only thing I honestly think will annoy you, is having the port at your head level. That air gets VERY annoying (I just did a wall witht he port forward at the top, and pissed the hell out of me daily) so I chaged boxes.
Good job so far btw
I wasn't throwing it out there just to hate. It would **** to do all that work and not have the enclosure strong enough. If you plan to glass/matt that will make the corners stronger, but make sure the top/bottom are braced as those are BIG panels, same with the sides.
I'd skip the Liquid Nails as I used it to glue/screw 2x4's on the outside of my last wall and when I took it apart a month later they fell off once the screws were removed. Unless I got 3 tubes that were bad because it didn't bond worth a shit...
Port at head level = easy hair tricks LOL
power-fanatic07
Knockin Doors Down
power-fanatic07
Texas
blackv62009
