'02 Civic Stereo Installation
ccohen
Hey car audio folks,
I apologize for first time posting as a cry for help. I turn to the experts in a time of need, so if anyone can offer assistance, I will truly be thankful.
I'm trying to install this new Pioneer stereo (X2600UI) in my '02 Civic LX, yet I cannot figure out why it's not working. I've replaced a blown fuse (interior - 7.5w radio), but still, no dice. It will not power on. The wires are secured together and bound with electric tape according to correct color coordination. Earlier today I was able to get it to power on for a little bit (under a minute), but slightly moving the unit caused it to loose power (and it has not worked since). Any experts out there that can offer me some advice? I really appreciate your time,
Thank you so much
Link to a video of my setup:
It could be a few things, first, check to see if your headunit has an internal fuse, this could be blown. Next, check your radio/audio/stereo fuse located at your dash panel fuse box to see if that's blown. If all power is running properly and everything is wired correctly (ex:12v constant to 12v constant, 12v switched to 12v switched, Ground to Ground) then it could be your headunit that has a problem. Try installing a different stereo to see if that one gets power. If it does, then its your headunit, if not, then your car could have an internal wiring issue.
ccohen
ccohen
Atlanta
CrossoverOre
