SOLD 02-04 Ford Explorer 6 Disc CD Player OEM
  • 4
slam
Original Factory OEM 6 Disc CD changer/radio for Ford Lincoln Mercury
This is an original Ford part 4L2T-18C815-CE.
You should be able to simply unplug your old one and plug
this one in to the factory wiring.
Will fit:
A2002-2005 Ford Explorer
2001-2004 Ford Mustang
2003 Lincoln Navigator (Early Production)
2003-2005 Lincoln viator
2002 Lincoln Navigator
2002-2005 Mercury Mountaineer
The CD-6 Radio offers a host of selection, navigation, and access features, including:
Random shuffle within CD or across CDs
Loads directly into the CD slot
Direct access to CDs through presets
Selective eject and load capabilities
Easy-to-use display shows continuous status of CDs
Steering wheel and rear seat control compatibility
Cellular phone interface
Plays burnt CD's
Bench Tested, in 100% working condition
Buttons, illumination, knobs, LCD and all work perfectly
200 shipped
813
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
slam
slam
fort worth, tx
mcorrunker@gmai
    Jun 1, 2024
    May 31, 2024
