01 F-150, Mach 5 10" IXL, and SAZ1000d or 1500
havinnoj
I have an 01 f-150 supercab. I'm putting a box under the seat with 1 sub.
I'm thinking I'm going with a Mach 5 IXL5 10" driver - link http://www.affordabledrivers.com.au/...&products_id=4
It wants atleast .6 cuft in a sealed box and a mounting depth of 5.5" - check out the Dimesions heading.. I'm taking the "depth" to be mounting depth.
If I picked up a music moose single box, link http://musicmooseaudio.com/ford_f_150b_single.html
it'll yield .84 cuft and has a mounting depth of 5.75"
The sub is:
1000 watts RMS
Coils wired in series (4 Ohm nominal impedance),
Impedance: 2 + 2 Ohm (DVC)
The sundown 1000 is:
----RMS power, 2 ohm linkable/dual mono
1800W x 1CH
----RMS power, 1 ohm mono
1000W x 1CH
----RMS power, 2 ohm mono
600W x 1CH
----RMS power, 4 ohm mono
300W x 1CH
The Sundown 1500 is:
3000W x 1CH
1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
400W x 1CH
The headunit is an alpine cda9886 with infinity 6032cf 2ways in all 4 corners. I want to throw a Sundown 100.4 to these speakers.
What do I need to do as far as batteries and alternators?
Anything else I'm overlooking in this setup? I've never put one in a truck..
You might need to add a second bat if your voltage drop is too bad.
But just try it out first, do the Big 3, and see where you stand
The big 3 being: Alternator to battery positive, engine to chassis ground, and battery to chassis ground?
Any thoughts on this in an extended cab f-150?
The 1000D is plenty. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
k Cool //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
How about the box and the sub setup?
Amp for the speakers?
havinnoj
havinnoj
portland
havinnoj
