01 cavalier lol
First, you have to drain the crankcase oil out and drill your engine block to convert it to 2 stroke. Then cut the exhaust off and run 4" front to back = Happiness.
To drill your block for two stroke, get a 1 Inch bit andrill a hole just below the spark plug. poke a piece of rubber hose into the holes and attach them all to the hose coming from your fuel pump via duct tape. Full in the 1" holes with JB weld around the hoses.
Drain the gas tank and fill it with a 1 part oil 25 parts gasoline mix.
Drive it. It will rock- trust me.
yeah thats how you get the msot power but thats the cheap way. i'd go to the hardware store and buy a fitting to attach hoses to the fuel pump line some sort of splitter rather then jsut tape cause that may come loose and you'd lose power
k thanks for spammin my thread dumbasses, i just wanted something to play with, driving into a ditch good suggestion retard
Swallow a knife, choke on a fork, jump in a fire, get hit by a truck ... and above all else ... shut the fuck up.
Kaltenberg
Kaltenberg
WI
Kaltenberg
BP1Fanatic
BP1Fanatic
