01 cavalier lol
lol, i think that would look pretty bad, thanks for the help tho, ill ty it for fun sometime. Anything else that doesnt stick out so much?
you do know you will need two of those if you plan to run dual exhaust. which is the only way you're going to get any power out of that thing. engines that big need to breath in and out LOTS OF AIR. also dont forget a cold air induction... the problem is they only work when its cold out.
First, you have to drain the crankcase oil out and drill your engine block to convert it to 2 stroke. Then cut the exhaust off and run 4" front to back = Happiness.
To drill your block for two stroke, get a 1 Inch bit andrill a hole just below the spark plug. poke a piece of rubber hose into the holes and attach them all to the hose coming from your fuel pump via duct tape. Full in the 1" holes with JB weld around the hoses.
Drain the gas tank and fill it with a 1 part oil 25 parts gasoline mix.
Drive it. It will rock- trust me.
Kaltenberg
Kaltenberg
WI
Kaltenberg
