'00 Contour 130A alt -- dimming
n2audio
OPTIDRIVEN
380w a/b
700w D
I've had this set up installed with two other electrical systems -- one a 75A alt, old but big battery -- gave me low voltage at idle, but ran fine while driving with minor dimming at high volume on the road.
Same car as above with a 110A alt - same battery -- Steady 13.8-14v at idle, very slight dimming on the road.
That car had a fairly demanding stock electrical system.
Contour - 130A alt, stock battery, average condition. Pretty basic stock electrical system. Obvious dimming at high volume regardless of RPM's.
I added an 8 ga wire from the alts to the batt (+) in all 3.
I've never had dimming noticable enough that it bothered me, but I want to improve it on this car.
Does anyone have any experience with the big 3 for Contour/Mystique/Cougar? Before/after reports?
I have plenty of 4 ga lying around.
I've found a wiring mod for the alt involving the Volt. Reg. sensor wire, but I don't want to go that route until I've exhausted all the usual remedies.
I might run a ground wire if it comes to that, but about every car built in the last 20 yrs is unibody, including my previous car, and my dimming was less with a smaller alt and similar grounding point.
do the big 3 and get a decent battery i had almost 1700wrms on mine with minimal dimming on my 96' tour, the stock alts are actually pretty decent considering the car they are on. Lol.
n2audio
OPTIDRIVEN
n2audio
Lawrence, KS
pre98zetec
