sealed box
  1. T
    10w7 enclosure (Sealed JL ProWedge vs. Gately Audio Kerf/Slot Port)
    I've been enjoying the 10 W7 in a sealed pro-wedge for a good 2 years now and I'm considering switching things up. Gately is now pre-fabing W7 boxes to JL spec and that has me interested while I save $ a custom 6th order. Will I miss the SQ I've come to love by going ported? I'm only...
  2. S
    Help: matching sub to my amp. Open to reboxing.
    Looking to upgrade my sub/box preferably a sealed setup. Appreciate your help! 1) Number of subs preferred: One Subwoofer preferably in a sealed box 2) Size preferred (if configuration allows): 12” 3) Budget: $5-600 4) Power to be used (which amp(s), include which resistance): NVX NDA105 -...
  3. H
    Did I ruin new my subs because even getting to listen to them?
    Just finished my amp install (brand new memphis prx1000.1 mono) and was going to wiring my Two 4ohm dual coil Sundown Ev3 10" subs in parallel to achieve 1 ohm this morning. After speaking with the authorized dealer for almost an hour yesterdsy, he made it pretty clear that he was sure sundowns...
  4. I
    2 10 INCH SUBS TO 1 MONO AMP
    Hey everyone, I'm pretty new to car audio, and I have some questions on mono amps and subs. I just purchased 2 10 inch subs.  They are the Polk Audio DB 1042 SVC.  It's a 4-ohm sub with single voice coils.  I also purchased a sealed box for these subs...
  5. Somchine13
    Fi Q and prefab sealed box
    Noob question: Would a prefab sealed box from ebay work just fine? This is the spec of the box. Dimensions in inches: 13.5" Width x 13.5" Height x 13.75" Top depth x 13.75" Bottom Depth Volume per sub: 1.0 cubic feet. Mounting Depth: up to 13.75
  6. man_n_da_trunk
    04 GRAND MARQUIS!!! FIRST PRO BUILD!!!! 4 APLINE TYPE X's
    Wussup Car Audio experts, and fans. This will be my first professional build so any help that you can give me would be great. First off Ive been planning this build for a year now. Just got back from afghanistan and im going to be installing this system over the next couple of months ill keep...
  7. TreyE
    TC Sounds LMS-R 12" Sealed Enclosure Size?
    Hey I just recently bought a single cab and want to manufacture a way to fit one of these depending on box size. I know no one has experience with these subs, but I do remember that the LMS's need small sealed enclosure sizes? (If I remember correctly) Trey
  8. V
    type r 12 sealed box question
    Hey guys I have two alpine type r subs(2010 models) with two alpine pdx-m6 amps(2010 models). I am going to build a fiberglass enclosure for these and was curious as to what size the boxes should be. The manual says .9ft per sub but I was just curious as to what you guys thought. The alpine...
  9. new box
    new box
    3 cubes sealed
