Running 4 pioneer 6x8" (75w rms ea) (2) in my front doors and (2) in the back deck powered by a pioneer sphBT10 50w.
I also built a board and placed (3) 6.5" prv's (100w rms ea) in my back seat (seats lay down for trunk access).
When I had my prv's connected to a taramps ts400x4 4 ch amp, it was...
This question may be quite straight forward, but I cannot find an answer anywhere. I am new to this forum but I found the formula to ballpark estimate my total amperage. I do not understand one part. When you calculate this, do you add up the total RMS of the amplifier AND the subwoofers it will...
Hello.
First sorry for mi bad english, i´m spaniard.
I have this main unit. I add a video to check the real 42 rms watt of this head unit, because is not the normal output for a main unit.
I want a set of 6.5" Component Speakers.
My kind of music are rock, heavy Rock and alternative rock...
Hello, new here... obv. Any help or advice is greatly appreciated... then scrutinized haha.
TL;DR to follow.
I have two 10" Powerbass (I know... they were free) PB-B105D 250w RMS 350w Peak DVC drivers.
Couldn't find any info on these so I measured the impedance using a multimeter, which...
So here in my room I got bnib my Fi Audio BL 12 D2 w cooling and flatwind coil options. Took a month to get but was well worth the wait. I Also got bnib a SQ Q2200.1 and was wondering if I over did it... I know the BL is 1500rms and heard it can handle more but was wondering if 2200 is too much...
There are so many amps put there, how do you know if it will really put out the RMS it claims? I usually add the fuses together and then multiply by ten, so (30A+30A)x10=600RMS. But I don't know if that actually works. Any tricks?
