Buck
little alien on campus
Here's a cool read:@Buck , generally speaking, would you say it's worth putting a tapped horn in a car over a ported box, given that you're using the right woofer or do they generally take up too much space for that application?
Simple Tapped Horn Tutorial using Hornresp
Tapped Horn Design We're up to v34 now, and there is a new download link. Get it here: http://www.hornresp.net/ After reading maxmercy's excellent post on front loaded horn design, I thought I'd share what I know with respect to tapped horns. As I've said all along, I am an amateur, I do...
Xmax considerations from that @Old_Slapper :
"Select a target low frequency response cutoff. Realistically, a low corner of 66% of the drivers Fs in free-air can be reached without losing too much efficiency or sending excursion through the roof. Higher frequencies = smaller boxes and higher efficiencies. It is all about the compromises."
That's what I was working on understanding and trying to learn without using hornsrep is develop a way for myself to do that without a program. But anyways I'm a nerd.
