Evl
  • 6
Just depends on what you want to spend. I'm selling one of these, never installed, still in the box for $300, shipped - about 2400 watts at 1.14 ohms.
You will want to wire 3 of the subs 2 coils in series Each 8" in series so all three are at 8 ohms, then run that group with the fourth (it's 2 coils wired in parallel to 2 ohms) then all in parallel to the amp for a 1.14 ohm load.
it's that or all four in a series/parallel configuration for a 2 ohm load. All 4 in parallel will knock you down to around .5 ohms, not a lot of amps under $5-600 dollars that I can think of that will take a .5 ohm load.
What is your budget?
If you wire each dual 4 ohm VC subs VC's in series to 8 ohms then run all four in parallel to end up with a 2 ohm load to the amp, bunch of amps that will get close to 2400 watts at 2 ohms.
$260
$599 (2500 watts at 2 ohms)
$500 (offer) 2300 watts at 2 ohms
$550 3000 watts at 2 ohms
$350 2000 watts at 2 ohm
I don't buy this companies product, the corporation is part of the Russian Federation, that just me.
$350 for 2200 watts at 2 ohms
So as you can see, any number of options wait you.
There are several good amps
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
SAMUELA81
SAMUELA81
California
AnthonyO
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
