Static electricity help
5t4y_50L0
Iv noticed a lot of static electricity when I get out the car, recently more since my voltage has been (15v) high and negative battery terminal getting corroded. Could there be a definitive reason to high static electricity?
Bad ground, not enough ground or too much ?
It seems you may want to consult a general automotive technician or electrician regarding static electricity and battery issues. However, common causes for high static electricity can include environmental factors, poor grounding, or issues with your vehicle's electrical system.
The whole car is a conductor of electricity. Iron. Magnetic flux around wires and cables. Does it feel like a shock? I some times experience this. Use clothes that insulates you to the seats. Sweaters and long pants, shoes, and socks. Static electricity is excess electrons on the surface of cars. Metal area. Battery is the sole producer of electric. Though only 12 volts, the quantity or amount is a lot. Larger measure. This quantity measures is called quantum. And it is electricity.​
Static grounding belts were common in the 50's and 60's, and you can still get them. Basically they're a strap that connects your car's metal to the ground (earth) to eliminate static. Kinda ugly, but they work.
5t4y_50L0
5t4y_50L0
Oklahoma
CertifiedHoodClassic
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
