You stated that X would band you for speaking poorly against Trump. Now you're only pointing specific ones. I don't know the entire story behind them, nor do I care to research it. My response was proving you wrong that X account will not be deleted if you speak poorly of Trump. I proved you wrong, so now you're trying to flip the claims.
If I'm only "pointing to specific ones ", that means it happens. Are you saying that only because it happened to some people, that it never happened? Interesting.
I guess that means since only a limited number of people have won the lottery, that means no one has ever won the lottery?
Your logic is a failure.
Nice try!
Fact:
the questions you are asking about the towers are meaningless. The conversation was directed to only one tower. The one where the fire started. I explained this to you at least a half dozen times, and you insist on either playing stupid or you just don't have any sense of simple math.
You think only one water tower with 1,000,000 gallons of water should be able to put out a 200,000 acre fire? And that a reservoir with billions of gallons in it is not enough for that tower/tank?
You can't even tell me how many towers there were in the general area, how much water the tower pumps can move, or how much water was in the reservoir.
But, do you want to argue that you know what happened in the fires and why they burned out of control?
That's laughable
I'll say this one more time.
Fact:
One tower was to have two sources to fill it. This is the tower where the fire started. For a year, one source was shut down. Due to this, the tower was not able to fill fast enough from just the one source. Do you now understand? Can you comprehend what I'm telling you, or do you need me to draw and picture?
You said that the source feeding the tower had a 36 inch pipe. That is a fact.
So, what was the pump capability of the pump that was feeding that tower from the 36 inch feed pipe?
Can you comprehend the question, or is it too confusing for you?
I'll ask it again: what is the feed capability of the pump connected to that "single tower "?
So you are saying that Trump was harder on gun control than Biden? Ok, prove it? I'll listen. I know what laws each of them put in place, but I'm curious on how you believe this. At the same time, I would like you to research on the gun laws that Biden tried to put in place.
I'm saying that gun laws became more restrictive under Trump than they did under Biden or under Obama. It's a fact.
Only the two gun laws made it through Congress during Obama's eight years in office. Neither of those added any restrictions.
Trump added restrictions. Bump stock ban. Stricter background checks.
Biden added red flag laws, but while he was POTUS, constitutional carry was reinstated in New York.
Trump loses on the gun front.
I know it was poorly written, but it is quite clear.
It's unclear BECAUSE it was so poorly written. Try harder.
Name something that Biden did that was illegal and should have been brought to court.
Nothing comes to mind, after all the ones the Republicans tried to claim turned out to be BS.
You obviously have something in mind, so go ahead and post it, instead of trying this silly dance.
