You think posting a picture of a stereo amp chip from
eBay is proof that a MONO amp has multiple outputs?
You tried the same shit with a schematic of a different stereo amp. And failed.
You are too funny.
Regardless, here is the diagram for the chip in your picture.
It only shows one output leg for each corresponding input. Leg 10 and leg 13 are singular audio outputs.
Were you trying to prove yourself wrong?
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://adjuntos.yoreparo.com/default/0006/50/88c71053eb748a3e7b396df6cc213af224a4905a.pdf
Oh, and for Spokey: A "chip" is any number of integrated circuits in a single device. Have you heard of the term "IC" for Integrated Circuit?
A manufacturer listing an op amp as an "IC Chip" would be redundant. Do you have an LCD Display on your calculator? Do you ask for a Jack Daniels whiskey at the bar? Maybe you do.
Here you go:
"integrated circuit (IC), an assembly of electronic components, fabricated as a single unit, in which miniaturized active devices (e.g., transistors and diodes) and passive devices (e.g., capacitors and resistors) and their interconnections are built up on a thin substrate of semiconductor material (typically silicon). The resulting circuit is thus a small monolithic “chip,” which may be as small as a few square centimetres or only a few square millimetres. The individual circuit components are generally microscopic in size."
Integrated circuit, an assembly of electronic components with miniature devices built up on a semiconductor substrate. The resulting circuit is thus a small monolithic ‘chip,’ which may be as small as a few square millimeters. The individual circuit components are generally microscopic in size.
www.britannica.com
You made a piss-poor attempt to spin off and not have to prove your claims. You failed.
Now, show me a schematic of ANY car audio amplifier that has multiple outputs coming from a mono amplifier.
Hell, zoom in on YOUR mono amplifier guts and show me the chip that has multiple audio outputs from a mono chip.
