Current events discussion
The point is Rob, on a car stereo amp the speaker outputs are not directly connected to the AMP CHIP. Show me what an AMP CHIP is in a car stereo mono amplifier.
Like these? How many output legs do you see on them?
But I obviously faked the existence of the chips, the datasheets, the schematics, probably the companies that made them. It's the only way I could be right. Right?
So, why don't you show me a schematic of your unicorn mono amp chip with multiple outputs?
Spokey can't seem to back up HIS claims. I'm sure YOU must be able to.
No, you said AMP CHIP... not power transistors.
That don't say amp chip anywhere...
Here is an amplifier chip. Typically used in car audio head units.
You think posting a picture of a stereo amp chip from eBay is proof that a MONO amp has multiple outputs?
You tried the same shit with a schematic of a different stereo amp. And failed.
You are too funny.
Regardless, here is the diagram for the chip in your picture.
It only shows one output leg for each corresponding input. Leg 10 and leg 13 are singular audio outputs.
Were you trying to prove yourself wrong?
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://adjuntos.yoreparo.com/default/0006/50/88c71053eb748a3e7b396df6cc213af224a4905a.pdf
Oh, and for Spokey: A "chip" is any number of integrated circuits in a single device. Have you heard of the term "IC" for Integrated Circuit?
A manufacturer listing an op amp as an "IC Chip" would be redundant. Do you have an LCD Display on your calculator? Do you ask for a Jack Daniels whiskey at the bar? Maybe you do.
Here you go: "integrated circuit (IC), an assembly of electronic components, fabricated as a single unit, in which miniaturized active devices (e.g., transistors and diodes) and passive devices (e.g., capacitors and resistors) and their interconnections are built up on a thin substrate of semiconductor material (typically silicon). The resulting circuit is thus a small monolithic “chip,” which may be as small as a few square centimetres or only a few square millimetres. The individual circuit components are generally microscopic in size."
You made a piss-poor attempt to spin off and not have to prove your claims. You failed.
Now, show me a schematic of ANY car audio amplifier that has multiple outputs coming from a mono amplifier.
Hell, zoom in on YOUR mono amplifier guts and show me the chip that has multiple audio outputs from a mono chip.
You are too funny.
Your diagram didn't say amp chip...henceforth not an amp chip...
You are too funny.
You can't backpedal out of this one. YOU made a mistake and said AMP CHIP.
Move on.
Move on.
Ahhhh, so neither you nor Spokey can prove your own bullshit, and it's time to "move on" because I used the term "chip" which is interchangeable with "Integrated Circuit"?
You two are genuinely pathetic, and just spent PAGES on this thread proving it, when you could have spent a single post just proving your claims of a mono amp with multiple outputs.
To avoid claims to the contrary, would you like all the words that can be interchanged with "pathetic"?
Jimi77
Premium Member
CarAudio.com VIP
Jimi77
Denver, CO
ThxOne
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
