Amps protecting
I have two 10ks I lost one yesterday and I'm not sure why looking through the backplate I can't see anything burnt . I have solid electrical it wasn't overheated or clipped. I wired the all 4 subs to my one at 1 ohm today and it went into protect twice but came out of it. I never had these problems till I walled it. What could be going on? .I stay above 15volts amps don't get over 130 degrees. I ohmed my subs at at the amp and they ohm out . Wasn't playing below tuning anyone have any clues ?
Lower peak impedance or a change in where the peak impedance happens due to the wall.
Possibly . I'm running the surge 10ks tho I would have thought they could handle it . I was at half ohm giving them all they had before and no issues. I did go from grounds at the seat bolts to grounds from the alt but they test good and my voltage holds better so I don't think that's what it is. I did turn the gain up a bit but I never seen clipping. Maybe I need to turn it down a bit .. thanks !
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bass so loud it HZ
