Ground loop issue
JohnPD
I’ve tried all of the suggested fixes in the sticky thread, so I’m going to try the ground loop isolator. I’ve got a very slight buzz just from the tweeters in my component speakers. I’ve changed and checked everything and all is good. Where do I hook these things up to? Back of the head unit, or at the amp?
I'd use the isolator as close to the amp as possible. That said 9 times out of 10 a ground wire (~14awg) run between the amp ground and the HU or pico fuse fix (see pic) will resolve a ground loop. If you have outboard comps, try moving the crossovers.
How do I run a ground wire from the amps ground to the head unit? Where do I ground it on the head unit? Tap into the existing head unit ground that’s on the wiring harness?
JohnPD
JohnPD
Ravenna, Ohio
2023 LTZ
