How to connect 4 speakers on a 1-channel amp
ianik777
131
Mauritius
Hello. need to power 4 deaf bonce speakers of 180 watt rms each at 4 ohm and been told that i may use the sound digital 1200.1 which is a mono amp.
AMPLIFIER
35634
SPEAKER
35635
how should i connect the speakers so that i get the max power?
Wire them all in parallel. Final load will be 1 Ohm. Use a multimeter to get 28v AC from the amp. That will give each speaker around 200 watts RMS.
and what if i want to connect the 4 180 watt rms speakers to a banda 800.4 amp with below specs:
35652
do you think that i can bridge the 4 channel to get 2 channel of 2 x 400 watt rms. then connect 2 speaker in parralel on each channel to get 200 watt per speaker?
Supposedly it is safe to do so. It says 2x400wRMS @2 Ohms AND 2x400wRMS @4 Ohms. I thought only JL Audio amps did this magic.
HAHAHA. thought that i had to invest more money go get amp giving 200 watt per channel .but seems that the banda amp can do the work and give enough wattage to make the speakers scream. hope that the amp will be durable and that the speaker gets what they want and do not blow.
Better off using the 4 channel, those smaller speakers are not meant for 4 ohm or 2 ohm unless they were made for it. So stick with a 4 channel instead and run them at 4 ohms otherwise you will blow them up. What speakers exactly and specs? If that 180 is at max then you want to keep them at RMS levels not the max it can handle.
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
ianik777
ianik777
Mauritius
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
