Why is my clip light going off?
Kohen36
102
Alabama
I have 2 American bass XFL 10” in a 2008 Toyota Tundra .i have a custom built box that has 3 cubic ft airspace .my amp is a cab 22. These subs sound very good at low and med volumes but whenever trying to demo or playing decently loud I usually encounter my clip light going off and I am trying to figure out what it causing this?. Watching my electrical gauge it doesn’t seem to be bad voltage as when the truck is running the needle doesn’t move to much down from where it usually sits. I also doubt that my amp is being pushed too hard as it doesn’t really seem like I’m experiencing 2500 watts.my system was tuned by a shop that seems very knowledgeable and didn’t just tune it by ear. If anyone could help me this would be greatly appreciated
It would be helpful to know what your voltage is at when clipping occurs. Do you have a multi meter?
Measuring voltage at the amp could illuminate things.
Unfortunately I do not
unfortunately I currently do not but I will try to get ahold of one
If you have a Harbor Freight in your area, a usable multimeter can be had for less than $10.
Ok thanks for the info I will grab one soon , would you be able to answer one of my questions form my most recent thread? Basically my box is vibrating way to much and the person who made the box suggested putting drywall screws where they go through the first wall then hit the port wall. Do you think drywall screws are going to stop this or will I have to go to wooden dowels
Pre-drill the holes and use 1-½" or 2" drywall screws every 8".
I did this with a couple screws at the top where the guy confirmed they would hit but if I started going down towards to the middle wouldn’t the screws not work since they would have to be so long? It would I have to use dowels near the middle
I am not well versed in box design, so I do not know outcomes based on over/under sizing. The one thing I do know is that too big of a port will...
807
Pick one and stick with it. http://www.thesuicidaleggroll.com/gain.htm
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
857
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
Kohen36
Kohen36
Alabama
Kohen36
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
