Left channel out
Hiker
MS
I recently lost volume in the left channel of my minivan. The front has no volume whatsoever and the rear speaker is barely audible. Thinking it may be the radio itself, I swapped receivers from the aftermarket JVC with the factory radio in my 2003 Dodge Grand Caravan and the same problem exist.
I'm left thinking it's the wiring but where and how would I test it?
Check connections to make sure nothing is loose or badly corroded at the speakers / head unit. Use a multi meter / ohm meter to test speaker wire where it connects to head unit and at speakers, assuming that vehicle doesn’t have a separate OEM amplifier or something which could change testing a bit. I’ve had at least one older car that the speaker wire broke where it passed through the door hinge area (in the rubber boot). Started cutting in and out then finally went dead and I had to run new wire. You can of course take each speaker out that is not working and test it out of the vehicle or try it in the other side to see if it still works okay.
I would first check that speaker. If they are OEM, their time may be through.
Hey, thanks for that, it seemed to correct the problem!
When I added the JVC receiver, I also got two new speakers for the rear and mothballed the old speakers. I recently used one old one to replace the front right speaker which was cracking.
With your suggestion, I swapped the left for the right, and sure enough, no volume. I took the other old speaker and both appear to be working now.
Thanks for the advice, thankfully, it was just the speaker and I didn't have to rewire.
Some of it plays well, some not so well lol. New decaf going around of "Break the knob off!" I have been playing and like it.
Sounds like you shorted the other channel so check you connections. Don't ask just look. Will solve your problem Every time. If you ever short out...
267
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
933
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
186
Hiker
Hiker
MS
Hiker
slater
    May 2, 2024
slater
    May 2, 2024
