Remote turn on wire
Dumb question, is the remote amp wire a constant 12v? I was under the impression that is wasn't.
It's a very low amperage 12v signal. The voltage just has to be high enough to be able to tell the device that it's connected to to turn on. If the remote wire dips too low or has no voltage, it turns off the device that it's connected to.
The voltage for something like amp turn on (remote wire) can come from any source you want it to. Like I say, if your remote wire isn't constant, then that's a problem, and your amp would turn off. You can measure these voltages with a volt meter or fluke or any DC voltage measuring device.
I had to tap into my cigarette lighter for my remote turn on. For some reason my Jeep had a 5 volt switched connection instead of a 12 volt from the stock stereo, causing a nasty pop when i turned off the vehicle. If the cigarette lighter stayed on constant with the key off, it wouldn’t have worked.
You can use a relay to create a soft turn on.
marscounty
marscounty
canada
Kickstand
