Wiring Question
The recommended fuse for each amp is in the manual. The 500x1 is 80 amp and the 300x4 is 60 amp
so use a main fuse of at least 140. A single run of 4 gauge at around 20 feet can handle 150 amps.
You should fuse for the max current draw of all amps combined. His is 140 a 150 will be close enough. If his max current draw is only 75 amps he would still fuse 4 gauge at 75 not 150. If he decided to step up to 1/0 he would still fuse at 150 not 350.
A single power wire in this case should be 150 near the battery. Then you need a fused d block by the amps. A 60 and 80 amp fuse there going to the appropriate amp. Those are to protect the amps individually since its one run of power wire and those amps have no fuses on them. Amps do have internal protection these days but fuses by the amps can't hurt as long as it's not undersized and being a bottleneck.
You can also run each amp separately to the battery. I do this. One 60 amp and one 80 amp fuse in its own fuse holder. No fused d block by the amps needed since they are powered by it's own line.
Should? Need?... maybe can would be closer to the truth man.
People who fuse for ea amp do so as a personal choice.
I had a 400A underhood and another where the dual runs came up thru the floor in back. Thats it.
28341
Fusing for the wire size where theres a chance of insulation failure due to an accident is all that's needed.
Fusing on a distro block is what some do. I never had/wanted to.
Yours looks fine same size wire. Its when you go from larger wire to smaller wires one would want to fuse.
Wow... you sure got some preconceptions on the needs/whys regarding fusing.
lol... same wire size?
In the system pictured theres 3 amps there and 1 uses dual 1/0 guage, 1 uses 4ga and 1 uses 8ga.
CAF vids are fine man. I fuse for wire size. Not estimated amp draw.,
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
metalheadjoe
