Thoughts on shallow mount subs in ported or 4th order enclosure.
tng83
I work in the car business and occasionally come across trade ins with speakers the customer doesn't want so I get to keep em and use em. I just sold the last set of Skar 10s I had been using in an enclosure I built and today was given a set of RF R2 12s and I already have a Rockford Prime 500 amp that will work perfect for them. I'm not intrested in building a sealed enclosure. Id rather not use them at all. Anyone ever have or see shallow mount subs in a ported enclosure or in a 4th order? What do you think?
I’ve done shallows in sealed and ported enclosures, but never in a 4th order. The reason for using a shallow mount sub in the first place is normally because space is an issue, and a 4th order box is usually not the ideal enclosure choice for small spaces.
Yea i just wonder if 1.5 sealed and 2.5ish ported would bring em to life. Just messign around with em til I sell the package and replace it with whatever else I wind up with but Ive never worked with shallows and have never seen anyone go bandpass with em.
Buck just designed a box a few weeks back for another guy on here for a JL shallow mount. I’ve seen it done, but never have myself.
If the sub doesn't recommend ported, you're taking a little bit of a gamble putting it in a ported section, even though it's still in a sealed section as well.
I know there are some shallows that will work ported, some shallows even work IB. It just depends on the sub itself. I did do a 4th order sealed-tapered t-line for a pair of shallow mounts that turned out very well. T-lines do not have the pressure inside of them that a ported box does, so that might worked with the sub I had a problem with in ported, we just didn't have the room to do that type of box.
The only good use for a shallow mount sub is for a midbass in your door, and that's my take.
RF does suggest ported as well as sealed. I just don't know if I wanna waste my time if 2 RF R2 12s wont be 'more' than 2 little Skar 200w 10s.
Polk DB seem to always sound so much better than most for drop inns...
707
I treat my vehicles to an extent where they become some of the quietest examples of that vehicle. It isn't cheap if you're buying quality...
Looks like you could raise the back seat maybe 2 to 2-1/2" use longer seat bolts and washers and frame/mold in the under carriage cavity of that...
14
tng83
tng83
Ponchatoula, LA
Buck
    Apr 28, 2024
    Apr 28, 2024
